  3. How to cut shape 45 degree at an arch
  • Subscribers 160
  • Views 13907
littleanne
littleanne over 14 years ago
anybody know what is the skill command to cut shape 45 degree at an arch..or any skill code will do.
appreciate ur feedback
  • Ejlersen
    Ejlersen over 14 years ago
    Hi
    Can you please ellaborate a bit more what you want to do, thanks.
  • littleanne
    Hi  Ejlersen,
    I want to cut shape at the corner . Pls refer to the attachment
    The shape is a for paste mask for shield. I’m able to cut the shape at 90 degree using skillcode.
    My ultimate goal is the chopping of the paste mask will be done by using skill code instead of manual chop
    The main problem now is for the corner area.i want to cut at 45 degree . I’m not sure what is the best command or built in function in for skill code
    anne
