  3. how to retain variable during skill session
  • Views 17128
Ejlersen
Ejlersen over 15 years ago
Hi
I've got a skill program that parses data to a new .dra file.
So the program actually saves the current session then start a new dra file and after it is finished with the dra file it reloads the original session.
I'm however experiencing that variables get lost so when I return to the original session. Is there any way to prevent this from happening.
At the same time I would like to clear the memory for all variables when the program terminates.
Best regards
Ole
  • Ejlersen
    Hi Dave
    That confirms my understanding.
    So maybe if I make a defvar it will work better.
    Currently the nextline variable that looses its value is not defined in a let statement, neither in a defvar
    How do you clear a defvar variable from memory when closing down the program?
    Best regards
    Ole
