  3. padstack path in dra symbol
  • Subscribers 159
  • Views 13149
Ejlersen
Ejlersen over 14 years ago
Hi
In a .dra file, ts there a way in skill (or any other way) to find the path where a padstack origins from.
Best regards
OIe
  • fxffxf
    fxffxf over 14 years ago
     no there isn't.
    You can use axllDMFileFile to return where a padstack is currently located on disk but it uses the current PADPATH to locate the file which may be different from the PADPATH or dra location that was used to initially load the padstack. The relibility of this location all depends upon the rules used in your company.
