  3. How to store components location
  • Subscribers 160
  • Views 13489
eDaNoy
eDaNoy over 14 years ago
Hello everyone, please help me store the value of the components location. for example. i want to get the components name layer and location. compName=dbid->name _layer=dbid->symbol->ismirror ("NO" for top and "YES" for bottom") _xy=dbid->symbol->xy cmbString=strcat(compname ";" _layer ";" _xy) i get an error on arguments #5, it says it should be string or symbol... please help, all of the variable holds a value, but when joining them using strcat it gets an error on the _xy which is the location...
  • fxffxf
    fxffxf over 14 years ago
     _xy is a list of floats so you need to convert it to a string which a sprintf can do with a %L conversion spec:
         cmbString=strcat(compname ";" _layer ";" sprintf(nil "%L" _xy))
  • GIL2004XP
    GIL2004XP over 13 years ago
    An alternate solution is to make use of the File>Export>Placement Command which can then be run on axlRunBatchDBProgram or shell function using command line "plctxt out"
