  3. Create component
  • Subscribers 159
  • Views 15039
Create component
Ejlersen
Ejlersen over 14 years ago
Hi
Is there a axl function to create a component without a device file
or alternatively an axl command to generate a device file from a symbol (.dra) file. I could probably do it with a script but would prefer an axl command.
Best regards
Ole
  • fxffxf
    fxffxf over 14 years ago
    In the board:
    •    axlDBCreateComponent but it requires a device file which wouldn't be that hard to create in Skill
    •    also there is axlWriteDeviceFile if you already have a comp that matches your requirement.
    To generate a device file require logical data which is is not part of a dra.
    You can make a template by trying the following:
     Use the non-public function: _writeDeviceFile(t_deviceName, t_className lt_pinNumbers)
          t_className is the device entry for CLASS
          You can get make up the pin numbers by iterating on the pins in the DRA, skipping mech pins and making a list of 'number' attribute from the pin ids.
     Other device file data like functions, properties. etc., in the symbol editor, you would need to obtain from other sourc.
  • djhutchi
    djhutchi over 14 years ago
    Doesn't work for me...
    \i (00:01:25) skill
    \i (00:02:27) skill '_writeDeviceFile("bozo" "clown" ("a" "b" "c" "d"))'
       (00:02:27) *Error* eval: undefined function - _writeDeviceFile
       (00:02:27) ERROR
  • fxffxf
     misspelled it - _WriteDeviceFile
  • Ejlersen
    Hi
    With this and other commands, is there a way to disable most of the reporting temporary? I would like to get only relevant reporting, the following info that I get is basically something I can live without.
    Any ideas?
    Finished loading SigNoise device libraries
        Checked 100 percent
    Creating device for r1206
    Performing a partial database check before saving.
    Writing database to disk.
    'r1206.dra' saved to disk.
    Opening existing design...
    Grids are drawn 400.000, 400.000 apart for enhanced viewability.
    Checking db records
        checking for orphans...
    Best regards
    Ole
  • fxffxf
    If this is done via a script, you can add:
         scriptmode +noinfo
    to the head of the script.
