  3. How to select a single segment of voids?
  • Subscribers 159
  • Views 13640
stillfish
stillfish over 14 years ago
Hi
I have tried to select a void segment by using the function
axlSetFindFilter( ?enabled '( "NOALL" "LINESEGS" ) ?onButtons '( "NOALL" "LINESEGS" ) )
and
axlAddSelectPoint()
But it didn't work.
Is there any way to get it?
Or anyone knows how the "show Element" icon implement its function to select object?
  • eDave
    eDave over 14 years ago
    On the surface this appears to be an oversight - I think your code should work. You can obtain the information by selecting the shape and looking at the voids attribute.
  • fxffxf
    fxffxf over 14 years ago
     You need to use VOIDSEGS not LINESEGS
  • stillfish
    Thanks for your help, it's work.
