  3. Check for crossing segments before axlDBCreateShape
  • Subscribers 160
  • Views 14340
Ejlersen
Ejlersen over 14 years ago
Hi
I'm reading in a file to create a shape, my problem is that if the shape is selfcrossing then I'll get an error
E- (SPMHDB-187): SHAPE boundary may not cross itself.
This terminates the program, so is there a way to check if a path is crossing itself before committing it to axlDBCreateShape so that I can avoid the program from terminating.
If so, is there a way to detect the coordinates for the issue and maybe even get it to heal it self?
Best regards
Ole
  • knuhcrek
    knuhcrek over 14 years ago
     Intriguing question.  the "grunt" method would be to step through each segment making up the exterior of the shape and seeing if it touches or crosses any other segment. You could speed up the process by recursively snipping off a segment to test against remaining elements of the segment lis.  axlLineXLine could be of some use.
    Good Luck,
    Chris Walters
    still hanging around
  • eDave
    eDave over 14 years ago
    Great to see you are still around Chris! I would be looking at the source of the problem. If you are creating a path, look at the segments. Arcs will cause you some problems with analysing segment by segment. Your routine shouldn't crash. You should be able to detect the nil result of the command and provide some debugging. Dave
