  3. Sorting with secondary parameters in assoc list
  • Subscribers 160
  • Views 14591
SkilSiao
SkilSiao over 14 years ago
Hi, I have a list looks like this...
mylist='((20 3.5) (15 2.5) (50 3.1) (20 2.8) (5 3.6) (20 3.6) (20 0.1))
if I apply sortcar with 'lessp, it becomes:
Skill >  sortcar(mylist 'lessp)
((5 3.6) (15 2.5) (20 0.1) (20 3.6)  (20 2.8) (20 3.5) (50 3.1))
i want to sort with respect to the 2nd element as well in the assoc list.
that is to have ( (5 3.6) (15 2.5) (20 0.1) (20 2.8) (20 3.5) (20 3.6) (50 3.1) ).
 is there a way to go with it?
 Thanks in advance.
  • aCraig
    aCraig over 14 years ago
    I don't believe there is a multi column sort. One thougt would be: after you do the sortcar you'd need to iterate over the list and create an array or table of sublists based on the "car". Then modify the sublist so the elements are '(b '(a b), then you can sortcar on the sublist. Once all the sublists are sorted you'll need to put them back to '(a b) and then rebuild the original list.
    Just a thought
    Craig
  • RFDTeradyne
    RFDTeradyne over 14 years ago
    Use "sort" which allows you to specify a sort function. It is passed two arguments and should return non-nil if a<b and nil if a>= b  Create one that does something like:
     (defun mysortfunc (a b)
     (if  (equal (car a) (car b) )  ( return (lessp (cadr a) (cadr b) ) )
     (return (lessp (car a) (car b) ) )
     I am doing this from memory and may not have gotten the syntax exactly right.  It the sort is backwards, replace lessp with greaterp.
  • SkilSiao
    Hi RFDTeradyne,
    Yes, the function works well. Thanks.
    Define the sorting algor as:
    procedure( mySortFunc(a b)
    prog( ()
    if( eq(car(a) car(b)) then
     return(cadr(a)<cadr(b)) else
     return(car(a)<car(b))
    ) ; end if
    ) ; end prog
    ) ; end proc mySortFunc
    and try:
    Skill> sort( list('(7 45) '(7 56) '(5 23) '(24 13) '(25 1) '(6 2) '(7 5) '(24 8)) 'mySortFunc)
    -> ((5 23)  (6 2) (7 5) (7 45) (7 56) (24 8) (24 13) (25 1))
