  3. How to get pinpair length?
  • Subscribers 159
  • Views 13553
stillfish
stillfish over 14 years ago
Hi all,
  Does anyone know how to get the pinpair length like the quick report shows?
I think there should be a function, but i cannot find it.
  • eDave
    eDave over 14 years ago
    I don't think there's a function.
    You need to get the length(s) using something like this:
     netObj = axlDBFindByName('net, netName)
     foreach(pinPair, netObj ->pinpair
       pins = pinPair ->groupMembers
       branch = car(setof(br, netObj ->branches, member(car(pins), br ->children) && member(cadr(pins), br ->children)))
       branchLen = 0.0
       pins = setof(br, branch ->children, br ->objType == "pin")
       foreach(path, setof(br, branch ->children, br ->objType == "path")
        end1 = car(car(path ->segments) ->startEnd)
        end2 = cadr(lastelem(path ->segments) ->startEnd)
        layer = car(path ->segments) ->layer
        padPolys = mapcar(lambda((pin), car(axlPolyFromDB(pin, ?layer layer, ?padType "regular"))), pins)
        branchLen = branchLen + if(exists(padPoly, padPolys, axlGeoPointInShape(end1, padPoly) && axlGeoPointInShape(end2, padPoly))
         then axlDistance(end1, end2)
         else axlDBGetLength(path)
       println(branchLen)
     Easy, huh?
    Cheers,
    Dave
  • stillfish
    Thanks Dave,
    I did not descript my question correctly. Actually, I want to specify the two end pins, rather than get
    the predefined pinpair object.
    However, it seems I can use axlPinPair/axlPinPairSeek to create pinpair , and then follow your routine to get the length, right?
  • stillfish
    Hi Dave,
    I tried the code above, but it does not work fine as expect.
    I guess the problem is that the net branch we can see in layout topology does not match to individual netObj->branches in database.
    It means even a net has several branch/stub segments, its netObj might have only one branch in netObj->branches. And this cause the  final pinpair lengths are all equal to the netObj total length.
