  3. Form placement options of axlFormCreate()?
  • Subscribers 160
  • Views 13499
stillfish
stillfish over 14 years ago
Hi all,
  I try to use the placement option arguments when i create my form,
like '("E" "Outer") or '("W" "inner"), but the argument seems not work.
On my screen, the form position with above two argument are exactly the same, why?
Have you meet the problem?
  • Ejlersen
    Ejlersen over 14 years ago
    Hi
    Yes, I see the same problem.
    Best regards
    Ole
  • fxffxf
    fxffxf over 14 years ago
    The placement suggestion is superseeded by the remembered window location. This feature can be disabled by setting the display_nosaved_geometry env variable. Basically, the suggested window location is only followed the 1st time the dialog is invoked, future invocations uses the last window location.
  • stillfish
    Thanks fxffxf,
    I found this env variable in User Preference -> Ui -> General
    and set its value to position, restart, then it is work.
    However, since this axlFormCreate argument depends on env variable,
    i think the availability of the argument is decreased ...
  • fxffxf
    This capability allows to the user to position the form to their liking.
    You as a programmer specifiy an initial "out of the box" location
