  3. Issues with axlDBCreateComponent
  • Subscribers 159
  • Views 13620
vramananx
vramananx over 13 years ago
In a design I am trying to create a duplicate of all the exisiting components (not symbol)
for this I am using the axlDBCreateComponent command,
This is my code
_CompList = axlDBGetDesign()->components
foreach(a _CompList axlDBCreateComponent(strcat(a->name "_T") a->deviceType strcat(a->package "_T")))
This works fine for all the components except for the discretes,
for example refdes C1 has a device name (devType) as C_0201_LOL_4V-0.1UF,X6S,15%,>3A
so i even tried to do the following
x = car(setof(a (axlDBGetDesign()->components) a->name == "C1"))
axlDBCreateComponent("C1_T" x->deviceType x->package nil nil)
this will give the message
E- (SPMHNX-9): Unable to find device file for 'C_0201_LOL_4V-0.1UF,X6S,15%,>3A'.
nil
I also tried to enabled and increased the allegro long name settings to 200 without any success
the typep of x->devType is string
also I tried to do the following, in assumption that I would be able to create a dummy device file with a refdes
axlDBCreateComponent("C1_T" "CAPTemp" "0201_LOL_4V_t") but i get the following error
E- (SPMHNX-9): Unable to find device file for 'CAPTEMP'.
nil
How do I resolve this?
or let me know how can I duplicate all the components in a design something similar to a logical edit parts where I can add a duplicate instance of all the components with the same device name, value, tolerance etc..
  • fxffxf
    fxffxf over 13 years ago
     These will require the value (4th arg) and tolerance (5th arg) to axlDBCreateComponent
  • vramananx
    no luck
    I tried that too
    axlDBCreateComponent("C1c_T" x->deviceType x->package nil nil)
    and
    axlDBCreateComponent("C1c_T" x->deviceType x->package "0.1uf" "10%")
    don't work
  • fxffxf
     It may be somewhat sensitive to the syntax of these items, try:
       axlDBCreateComponent("C1c_T" x->deviceType x->package x->compdef->prop->VALUE x->compdef->prop->TOL)
  • vramananx
    Works Now
    woof, but the syntax does say it could be nil :-)
     Cadence support told me to export all the device files and try it, but it won't work
    regards
     Venkata
