  3. ~ vs - operator effect on skill query
  • Subscribers 159
  • Views 1344
eDaNoy
eDaNoy over 13 years ago
 Good day everyone..
I have been notified by my leader upon using this ~ on one of my skill program...
he ask me the difference on using ~ with -, and i cant give him the right answer,
example: Taking radius of Rounded Square shape
Routine 1                                                            Routine 2
 (foreach item shape                                    vs       (foreach item shape
       radius=item~>segments~>radius                         radius=car(item->segments)->radius
)        radList=cons(radius radList)
upon validating the above routines:
i could conclude that routine 1 could give me the list of radius that i want without doing the cons function of routine 2.
these are my understanding.
Please help me about this operator...
thank you in advance. just needed it so badly, if i cant convince him, i will surely rewrite my program using what they had used to,  which is this -
please give some sample routine that make this(~) so usefull
thanks again
  • fxffxf
    fxffxf over 13 years ago
    In the Skill Language User Guide go to section Data Structures -> Access Operators for a description of the differences.
    For Allegro Skill dbids, there is no difference you can use either although most C/C++ programmers use the arrow operator except if you use to Skill program in the Cadence IC world where the squiggle seems to be more prevelant.
