  3. String Business in SKILL
  • Subscribers 171
  • Views 19565
nimoster
nimoster over 14 years ago
Hi Guys
I have some problems processing strings in SKILL. Basically I want to break a string into a list of substrings using "!" as delimiter. I found out that the "parseString"-command will do the job. But if one property is missing in the string, the parseString-command just ignores it. I better give you an example:
My string looks like that: "C419!100n!C0603!Murata!PartNo123"
In this case partseString works perfectly and puts each property in a own list field. But if e.g. the manufacturer property is not present and the string looks like this "C419!100n!C0603!!PartNo123" the parseString command interprets the "!!" as one delimiter. In this case I would have expected the funktion to generate a field with an empty string. But it doesn't, it just ignores it :-( So depending on the database entries I get lists with varying length which makes postprocessing more complicated.
Does anybody of you have an idea of a better solution or a workaround?
Martin
  • Adeliaa
    Adeliaa over 4 years ago
    Hey! Are you unsure where to make bitcoin transactions? With the best crypto app! Notifications, a user-friendly interface, and a dependable account protection mechanism are just a few of the features. The service is unique in that it includes practically all crypto exchangers from across the world, allowing you to trade without restrictions!
