  3. dbid:removed
  • Views 4210
dbid:removed
aeris
aeris over 14 years ago
anyone encountered a scenario similar to this
-- you cant debug because the dbid were instantly removed the moment you assign them to a variable
function/procedure as simple as this :
(defun MyTest ()
 axlSetFindFilter(?enabled list("noALL" "pins" "vias" "shapes") ?onButtons list("noALL" "shapes"))
 axlAddSelectAll()
 retDbid=axlGetSelSet()
axlMsgPut("%L" retDbid)
  1. I normally get dbids when I put retDbid in the skill command prompt, until lately im having this problem. The axlMsgPut shows all the dbid's value, but in my skill command prompt i have all the dbids removed
  2. Running the program as a whole have no error, its just that I cant debug dbid values
I have tried the following
1. Use same code to other PC -- normal as expected
2. Re-install allegro within the same pc with error -- still have error
  • aeris
     Hi Gil,
    thanks for the effort, i dont know if its normal, but it would be too tasky to debug multi line skill programs if its like this
    i dont encounter this before, i dont know if i installed some window program or what that it affect allegro even after re-installing it
     hope other members have experienced and solve this
     thanks
