  3. Is anybody using IDF/IDX transfer between Pro/E and Allegro...
  • Subscribers 159
  • Views 581
Is anybody using IDF/IDX transfer between Pro/E and Allegro (16.5)?
richardbat
richardbat over 13 years ago
Is anybody using IDX transfer between Pro/E and Allegro (16.5)?
If so what method do you find best to create/manage fixing holes in Pro/E?
From recent experiments if you create a mechanical hole in Pro/E as "HOLE" is shows up in
Allegro as a symbol with no name! (hotfix on its way)  whereas if you create the feature in Pro/E as a "Cut" then
after IDX import its a circle on BOARD_GEOMETRY/OUTLINE
Any experiences good (or bad) with IDX welcome
