  3. autosilkUtils.il
  • Replies 38
  • Subscribers 166
  • Views 36219
autosilkUtils.il
FormerMember
FormerMember over 14 years ago
 Hi All:
Hopefully Dave Elder reads this ?
I am running Allegro 16.5  S018 and tried to run the autosilkUtils.il SKILL script.
Everything seems to work except it does not put the DRCs into the walker popup window.
Hopefully someone can fix this ?
This is a great tool
Les
  • DE202408202727
    DE202408202727 over 14 years ago +1
    Hi Les, It should work. What version number does the utility show in the form? Versions after 8.23 are suitable for 16.5 although my latest (unreleased version is 11.04) Dave
  • FormerMember
    FormerMember over 14 years ago +1
    8.12
  • FormerMember
    8.12 from Allegro SKILL Code Library
  • Cadence GDD
    Cadence GDD over 13 years ago
    I'm trying tu use the silkutils skill but when I try to run the tools I get the following error message:
     Command > silkutils
    E- *Error* eval: unbound variable - ASU_defaultBdEdgeSpacing
    Select a handle or line segment
    Command >
  • DE202408202727
    DE202408202727 over 13 years ago
    Did you miss a step in the installation process?
    Do you have the latest version? See an earlier post in this thread.
  • Cadence GDD
    I installed the latest version and it works.
    Thank for your help!
