  3. smt pad skill
  • Subscribers 160
  • Views 14542
smt pad skill
elikmiz
elikmiz over 13 years ago
Hi everyone
I'm searching for a skill that can build an smt pad automatically.
I know there is a skill that build the shaps.
There is one that build the smt pads as well?
eliko
  • Pawandeep
    Pawandeep over 13 years ago
    Hello Eliko,
    The below code is taken from the Cadence docs which might be helpfull to you
    mytext = make_axlTextOrientation(
    ?textBlock 6, ?rotation 60.0
    ?mirrored nil ?justify "center")
    mypin = make_axlPinText(?number "1",
    ?offset 0:75, ?text mytext)
    axlDBCreatePin( "pad1" 0:0 mypin 45.0)
    mytext->justify = "left"
    mytext->rotation = 0.0
    mypin->number = 2
    mypin->offset = -125:0
    axlDBCreatePin( "pad0" -100:-100 mypin)
    mytext->rotation = -45.0
    mytext->justify = "right"
    mytext->mirror = t
    mypin->number = 3
    mypin->offset = 50:0
    axlDBCreatePin( "pad0" 100:-100 mypin)
    mypin->mytext = nil
    axlDBCreatePin( "pad0" 100:100 mypin)
  • eDave
    eDave over 13 years ago
    This code will build a pad stack:
    defun( MY_makeSMDPadstack (padName, figure, padx @optional pady, (soldermask t), (pastemask t))
     let((pad, pads)
    unless(pady, pady = padx)
    pad = make_axlPadStackPad(?layer "TOP", ?type 'REGULAR, ?figure figure, ?figureSize padx:pady)
    when(pad
    pads = list(pad)
    and(soldermask
    pad = make_axlPadStackPad(?layer "SOLDERMASK_TOP", ?type 'REGULAR, ?figure figure, ?figureSize padx:pady)
    pads = cons(pad, pads)
    and(pastemask
    pad = make_axlPadStackPad(?layer "PASTEMASK_TOP", ?type 'REGULAR, ?figure figure, ?figureSize padx:pady)
    when(axlDBCreatePadStack(padName, nil, pads), axlPadstackToDisk(padName))
    eg:
     MY_makeSMDPadstack("mypadstackname", 'RECTANGLE, 1.2, 0.6, t, t)
  • elikmiz
    Thnx, i need to save it as an .il file and use it as a skill?
  • elikmiz
    I think it dosnt make round corner pad ?
