  3. Access via properties
  • Subscribers 159
  • Views 17094
luanvn81
luanvn81 over 13 years ago
 Hi everyone!
   How can I get properties of Connected lines: , Connected vias: , Connected shapes:  in a Via.
    I have tried to use this:
           foreach(via allViasInDesign
               fprintf(writeOutFile "%L", via->Connected->pins)
           ...But  it returns to nil.  I wan to get layer name in "Connected lines: , Connected vias: , Connected shapes:" . Please help me.
 LISTING: 1 element(s)
              < VIA >
  origin-xy:    (-7031.130 -14189.120)
  part of net name:  GND
  Connected lines:     1 ( BL )
  Connected vias:      1 ( AL2 )
  Connected shapes:    1 ( AL2 )
  Padstack name:   VIA-BL-AL-50
  Type:            bbvia
  padstack defined from AL2 to BL
  rotation:  0.000  degrees
  Via is not mirrored
 Luan.
Tks.
  • Pawandeep
    Pawandeep over 13 years ago
    Hi Luan,
    You should consider using axlDBGetConnect function to get the attached items on a via.
  • luanvn81
     Hi!
      I have tried to do it but not success, I only want to get the layers that via connect to (line, shape pin)
    ex:    Connected lines:     1 ( TOP )                      ===> TOP
            Connected shapes:    1 ( BOTTOM )         ===> BOTTOM
    who can help me  ?
    Thank.
    Luan.
  • Randy R
    Randy R over 13 years ago
    See if this helps.  It should list all the via connections.  With some minor modifications, you can put the data into a list/array and they output it based on object type.
    axlSetFindFilter(?enabled list( "noall" "vias")
    ?onButtons list( "noall" "vias"))
    axlAddSelectAll()
    allViasInDesign = axlGetSelSet()
      via_connects = axlDBGetConnect(via t)
      foreach(via_connect via_connects
        printf("Object Type = %s,  Layer = %s\n", via_connect->objType via_connect->layer)
      );end foreach
      println("-----------------------------")
    );end foreach
    Good Luck
  • luanvn81
     Hi ! Thank for your reply!
      Your code works OK but if  a via connect to Pin (via on pad) ==> DRC occur  :
     E- *Error* fprintf/sprintf: format spec. incompatible with data - "Format is '%s, %s\n', argument #2 is nil"
       how can i get the layer if it connect to pin?
    Thank.
    Luan
  • Randy R
    The following will work for non-through-hole pins.  You can add additional case statements if needed.
    axlAddSelectAll()
        cnt_obj = via_connect->objType
        cnt_lyr = via_connect->layer
        case( cnt_obj
          ("pin"
            cnt_start = car(via_connect->startEnd)
            cnt_end = cadr(via_connect->startEnd)
            cnt_lyr = if( (cnt_start == cnt_end) cnt_start "***unknown***")
          );end pin section
        );end case
        printf("Object Type = %s,  Layer = %s\n", cnt_obj cnt_lyr)
      );end foreach
    );end foreach
