  3. Backslash path gives error in axlUIViewFileCreate with allegro_html...
  • Subscribers 159
  • Views 13529
Backslash path gives error in axlUIViewFileCreate with allegro_html enabled
pcbnagaraj
pcbnagaraj over 13 years ago
Dear All,
I am trying to show a html file to user using the axlUIViewFileCreate
file path is like \\server1\allegro_skill\tips.htm
I enabled the allegro_html env variable so that the page is displayed as html page.
The above file path is stored in Allegro_site variable
Mycode is as below
Filename = strcat(axlGetVariable("Allegro_site ") “\\tips.htm”)  ; this returns the file path
axlUIViewFileCreate( Filename "Allegro TIPS" nil)
this gives error that the file path is not found – reason is the double backslash appears in the Filename(\\\\server1\\allegro_skill\\tips.htm) which is not executed by axlUIViewFileCreate with allegro_html env.
I know that the double\\ is equal to \ and the strlen(“\\”) will count as 1.
When I unset the allegro_html I can able to read the file but the htm files is shown as text file with html syntax codes. I want the output to be as html enabled to show some links and pictures to the user.
How do I convert the double backslash(\\) to single backslash(\). I searched in the forum suggested to use rexSubstitute – I am not sure how to use this function.
Tried the axlOSSlash also doesn’t help. //server1/allegro_skill/tips.htm is not executed by axlUIViewFileCreate with allegro_html env.
Any suggestion is much appreciated.
Nagaraj.
  • Ejlersen
    Ejlersen over 13 years ago
    Hi Nagaraj
    I don't know how you can get axlUIViewFileCreate to work on this, but have another suggestion
     Filename = strcat("http file:" axlOSSlash(axlGetVariable("Allegro_site")) "/tips.htm")
     axlShell(Filename)
    That will open the link in the users preferred browser - that works :-)
    Best regards
    Ole
  • pcbnagaraj
    Thanks good trick.. excellent!!
    The issue with the axlUIViewFileCreate is the first // in the server name. C:/tips.htm though works.
    Nagaraj.
  • pcbnagaraj
    Just to inform – axlHttp will  directly launches to IE instead through shell command.
    Nagaraj.
