  3. How to use setVarWriteProtect to protect a defstruct variable...
  • Replies 13
  • Views 21396
How to use setVarWriteProtect to protect a defstruct variable?
Angeila
Angeila over 14 years ago
Hi Expert,
 I use defstruct to define a struct variable. For example:
 defstruct(mystruct aaa bbb)
 s1 = make_mystruct(?aaa 1 ?bbb 2)
 then I use setVarWriteProtect to make s1 write protected:
 setVarWriteProtect('s1)
 But when I change s1->aaa = 5, it still can be modified. Seems only s1 is write protected, but no its member variables.
 How to write protect the member variable s1->aaa? Is there anyway to do it in Skill if not by function setVarWriteProtect?
Angelia
  • fxffxf
    fxffxf over 11 years ago
    Try the code below. Also note that defstruct names are global so you should always prefix them to avoid collisions with other skill code.
    unless( boundp('mystruct )
        defstruct(mystruct width length))
    procedure(mytest(fileName)
          prog( ()
              inFile = infile(fileName)
              setq(tabel (makeTable 'layers 0))
              while(gets(line inFile)
                  lineInList = parseString(line " \n")
                  tabel[nth(0 lineInList)] = make_mystruct(?width nth(1 parseString(nth(1 lineInList) "=")) ?length nth(1 parseString(nth(2 lineInList) "=")))
    mytest("./test.txt")
  • balu soutani
    balu soutani over 11 years ago
    Thanks eDave Now it is working ,
    can you me in solving another,
    Why defstruct giving error when i use like this
    defstruct(stringToSymbol("test_structure") a b c)
    First argument to the defstruct is symbol and i am also giving the same.
    Is there any other to do like this.
    Balu Soutani.
  • balu soutani
    Thanks fxffxf for giving solution
