  3. How to use setVarWriteProtect to protect a defstruct variable...
  • Replies 13
  • Subscribers 160
  • Views 18465
How to use setVarWriteProtect to protect a defstruct variable?
Angeila
Angeila over 13 years ago
Hi Expert,
 I use defstruct to define a struct variable. For example:
 defstruct(mystruct aaa bbb)
 s1 = make_mystruct(?aaa 1 ?bbb 2)
 then I use setVarWriteProtect to make s1 write protected:
 setVarWriteProtect('s1)
 But when I change s1->aaa = 5, it still can be modified. Seems only s1 is write protected, but no its member variables.
 How to write protect the member variable s1->aaa? Is there anyway to do it in Skill if not by function setVarWriteProtect?
Angelia
  • Angeila
    Any one can help me out? thanks!!!
  • Angeila
    Help please...
  • eDave
    eDave over 13 years ago
    Hi Angeila,
    We're not ignoring you. It's just that we don't know the answer or if it is possible. I think it might be a question for a Cadence person.
    Why do you want to protect it like this? I can't really think of a good reason.
     Dave
  • Angeila
    Hi Dave,
      Thanks for your kindly response:)
      I created a structure which will be shared by other team members after I initialize it, and it will be surved as read-only purpose as I don't want it to be changed by other team members by accident.
      I am a greenhand to Skill language, when I refer to skill user guide, I found setVarWriteProtect can meet such requirement, but it does not work a defstruct variable.
      Could you please share me any feasible way to do so?
    Angelia
  • eDave
    Generally variables should be set to be local by including them in a let statement. Local variables cannot be changed by users.
    You may have to re-think your code if you want to protect the contents of a global variable. The documentation states that the behavior of this is not specified.
