  3. Highlight location xy in rpt file
  • Replies 8
  • Views 19401
luanvn81
luanvn81 over 14 years ago
 Hi everyone!
 I have a code which print out a report file (ex: a.rpt) as below:
Via Start Layer   Via End Layer     Via Location
ETCH/TOP          ETCH/BOTTOM       (5.5:42.5)
ETCH/TOP          ETCH/BOTTOM       (5.5:40.5)
ETCH/TOP          ETCH/BOTTOM       (6.0:84.0)
ETCH/TOP          ETCH/BOTTOM       (6.0:86.0)
 I want to highlight location xy with one color  and after I checked a location , it will change into one other color( at the same way dangling report check in allegro)
How can I do it?
Tks.
Luan.
  • Geoff
    Geoff over 14 years ago
    Hi Pawandeep
     You are right, the problem is the lack of highlighting in a user report. I should have read Luan's post more closely.
    I also would like to find out if it's possible to do.
    Geoff
  • Randy R
    Randy R over 14 years ago
    See if this does what you want:
    Go to Setup->User Preferences->Html and make sure the "Enable HTML" box is checked.
    Then open your file using File->File Viewer.
  • luanvn81
     Hi Randy & everyone !
       Thank for yours  advices. That really what I want, now it works as my expectations.Once again thank you very much.
     Luan.
