  3. exit skill function prematurely
  • Subscribers 159
  • Views 15795
Adamsen
Adamsen over 13 years ago
Hello.
I want to check for a condition and exit my function or program if the condition is not met. In other programming languages I would do this with return or exit statements. But this does not seem to work in skill.
Here is an example:
defun( foobar()
unless(axlGetVariable("ALLEGRO_BRD2ODB")
  axlUIConfirm("BRD2ODB not found. Please install!")
  exit() ; is not working, what should i use here to exit function?
;do some other stuff if condition is ok
) ;defun
if the skill window is open this will close on the exit command.
  • fxffxf
    fxffxf over 13 years ago
    use the return statement
    If you need return multiple levels you will may want to use err/errset which is basically a catch/throw let mechanism. You can read about this in the Skill Language User Guide (look for the section Using err and errset Together.
