  3. Changing the artwork output dir
  • Replies 7
  • Subscribers 161
  • Views 18121
Adamsen
Adamsen over 13 years ago
I want to write artworks to a design dependent output directory.
I have a script to create artworks,
olddir = "output"
outdir = "output/123456-ND-A"
axlSetVariable("ads_sdart" outdir)  ; set working directory to output directory
 sprintf(script
 "scriptmode +i +n +w +c\n
 setwindow pcb\n
 artwork\n
 setwindow form.film_control\n
 FORM film_control select_all\n
 FORM film_control database_check YES\n
 FORM film_control create\n
 FORM film_control ok\n
 setwindow pcb\n ")  ;end sprintf
 COD_replay_script(script)
 axlSetVariable("ads_sdart" olddir)  ;
If I set "ads_sdart" using setup user preferences, it works fine. If I use this script, the artworks is generated in "output" and art_param.txt is generated in "output/123456-ND-A". That does not make any sense to me. Any surgestions?
Alternatively I could move the files afterwards, but that requires much more unessesary coding.
  • Pawandeep
    Pawandeep over 13 years ago
    Hi Adam,
    I am assuming that there exists a directory named “output\123456-ND-A” where your brd file is saved and you want to save all the files to “123456-ND-A”
    I don’t know how are u calling the COD_replay_script(script) function in your code and you haven’t provided your complete code.
    Try running the below SKILL code. It should save all the files in the “output\123456-ND-A” directory.
    defun( pawan ()
    olddir = "output"
    axlShell("setwindow pcb")
    axlShell("trapsize 3215")
    axlShell("generaledit")
    axlShell("artwork")
    axlShell("setwindow form.film_control")
    axlShell("FORM film_control select_all")
    axlShell("FORM film_control create")
    axlShell("FORM film_control ok")
    Pawan
  • Adamsen
    Hello Pawan
    Thanks, for your input. The assumptions you made are correct. The dir structure looks like this, and they exists, at the time I run the script.
    123456.brd/output/123456-ND-A
    I tried running your script. But the result are the same for me.
    123456.brd
    /output/*.art
    /output/123456-ND-A/art_param.txt
    The artwork files are still in the output dir (which "ads_sdart" is set to in site.env), only the art_param.txt is in the output/123456-ND-A dir.
    COD_replay_script makes a scriptfile and replays it.
    procedure( COD_replay_script(cmds)
    let((script_file)
     script_file = axlDMOpenFile("ALLEGRO_SCRIPT", "tmp", "w")
     fprintf(script_file "scriptmode +i +n +w +c\n")
     fprintf(script_file cmds)
     fprintf(script_file "\n")
     axlDMClose(script_file)
     if( isFile( "tmp.scr")
     then
      axlShell("replay tmp")
      deleteFile("tmp.scr")
     else
      printf("tmp.scr not found\n")
     ) ;end if
    ) ;end let
    ) ; end procedure
  • Pawandeep
    Hello Adam,
    I got the desired results as you wanted it to be. Please refer to my code along with the dummy files that I generated in the attachment. I have used my code instead of yours. I am not sure where the problem exists.
    All files(*.art and art_param.txt) are generated in C:\pawan\output\123456-ND-A
    My board file resides in C:\pawan\test.brd
    In case you still see problems, please try to manually do the changes to “ads_sdart” env and see if you are able to do so and generate the artwork files in the any other path you define here.
    Pawan
    output.zip
  • Adamsen
    Hello Pawan.
    I tried to exactly as you described. Made a new board, put you script with the board, created output and output/123456-ND-A.
    Running your script I get same result as before. *.art in output and art_param.txt in output/123456-ND-A. When i set ”ads_sdart” manually it works as desired.
    Thank you for testing this. I will now open this as a support case, and take it from there.
  • wilef
    wilef over 12 years ago
    I have the same issue.  Did a hotfix update this issue?
