  3. cline midpoint
  • Subscribers 160
  • Views 13451
cline midpoint
skidog
skidog over 13 years ago
I need to find the midpoint of routed clines. I must cut in half exactly. Does anyone know a way to get this done?
Thank you,
Larry Thompson
  • Ejlersen
    Ejlersen over 13 years ago
    Hi Larry
    Having the coordinates at each end of a cline (l_pt1 l_pt2) you can calculate the length using axlMPythag to give you the length/distance of the cline
    length = axlMPythag(l_pt1 l_pt2)
    Then you can use  axlMUniVector to give you the midpoint
    result = axlMUniVector(l_pt1 l_pt2 length/2)
    Best regards
    Ole
  • skidog
    Ole,
    I will give this a try.
    Thank you,
    Larry Thompson,C.I.D.
    Sr. PCB Designer
    DFW Test Incorporated
