  3. SKILL script to get the pins sequence for a particular ...
  • Subscribers 159
  • Views 13846
SKILL script to get the pins sequence for a particular net
Klaap
Klaap over 13 years ago
 I wrote a SKILL script that returns all the pins in a net. However, I would like to have the order of these pins in that net.
For example:
- if I have a net NET_X with 4 pins p_1, p_2, p_3, p_4
- if there is a Cline between p_1 => p_3, Cline between  p_3 => p_2, Cline between  p_2 => p_4
 The output of the script should be  [p_1, p_3, p_2, p_4].
Palak.
  • eDave
    eDave over 13 years ago
    A branch should return the pins in order:
    pinDBID ->branch ->children ~>number
    Otherwise take a look at axlDBGetConnect. With a bit of logic you should be able to derive the sequence.
  • Klaap
    Hi Dave,
    Thanks, your advice was very helpful!
    I was able to get the sequence using axlDBGetConnect and by looking for Pin object among the connected elements.
    Palak.
