  3. Net Schedule
  • Subscribers 158
  • Views 14691
Net Schedule
Mstrghettorigg
Mstrghettorigg over 13 years ago
Hello All,
 I was wondering if there is a way to make a net schedule skill program that will allow me to select nets on the board and create T points for connections between 3 IC's easily.  Example would be main IC to 2 DDR2 in tree routing.
 We work off of netlist and do not have sigxplorer.
I would like to see something that would allow me to select multiple nets at once such as ADDR Group and be able to specify approximate area where I would like the T points for net scheduling without assigning it one by one.
 I would appreciate it if anyone has any suggestions.  On 16.3 performance L
 Thanks in Advance
  • fxffxf
    fxffxf over 13 years ago
    Look at axlSchedulNet and axlSchedule. To understand the syntax for the schedule argument you also need to look at the $SCHEDULE section in the 3rd party netin documentation.
  • Mstrghettorigg
    Thank you for the feedback.  I started looking into it, but I have no knowledge of making skill at all.  I'm going over the basics right now.
    If you have any suggestions I would appreciate it.
