  3. Can i get the skill file to rotate the footprint...?
  • Subscribers 160
  • Views 14672
soori3
soori3 over 13 years ago
 Is there any skill file to rotate the footprint with respect to the origin...?
I can able to select and rotate every shape and lines but coming to pins (as per row and coloumn wise) i was unable to rotate so, i need to create the footprint again...:(
It will be so much helpfull if i get the skill file to rotate the footprint.
 Thanks & Regards,
Suresh annam
  • soori3
    I have attached the file which shows the footprint rotation ...
    in symbol editor i have many footprint which needs to be rotation of 90 degrees but if i select all, except pins everything were rotatingFootprint_rotaion properly :(
    Can anyone tell me the easy way to rotae the footprint in symbol editor ...?
  • Randy R
    Randy R over 13 years ago
    When rotating, you need to select User Pick as the Rotation Point in the Options tab.  Then when it says in the command window "Pick origin to spin the element(s) around.", you type in "x 0 y 0" to rotate around the symbol origin.
  • soori3
    Thank you Randy now it clears my issue...:)
    Once again thanks for your help...
    Suresh Annam
  • nmz787
    nmz787 over 11 years ago
    That's a fine method of accomplishing the rotation... but it doesn't answer the original question regarding doing it via SKILL (which I am searching for answers on myself).
  • eDave
    eDave over 11 years ago
    Take a look at the axlTransformObject command.
