  3. non-blocking axlRunBatchDBProgram call
  • Subscribers 159
  • Views 15011
Ejlersen
Ejlersen over 13 years ago
Hi
I've created a skill program with a gui that needs to run an external program using axlRunBatchDBProgram.
However when I do this it blocks Allegro and the skill gui.
Is there a way around this?
Best regards
Ole
  • Pawandeep
    Pawandeep over 13 years ago
    Hi Ole,
    Please refer to ipcBeginProcess and other ipc functions for invoking programs without blocking the Allegro editor window.
    Pawan
  • Ejlersen
    Hi Pawan
    Thank you for your answer. As far as I can see from my initial tests closing Allegro will also close the process.
    Is there a way to start a program independently.
    I've so far tried bot the ipcbeginproces, axlRunBatchDBProgram and system without any luck.
    Best regards
    Ole
  • Pawandeep
    Hi Ole,
    I can think of something like running a Batch file(*.bat) outside Allegro containing shell commands.
    There is a batch command “allegro” available for us, where there is option to invoke it under no graphics mode and running specified script file.
    Pawan
  • fxffxf
    fxffxf over 13 years ago
    I believe there are 2 ways you can try:
    •  use the Skill system call to run a bat file that runs your program via a .bat nowait call. You should google "cmd nowait" to see how this works
    • use the axlShell function to execute the Allegro "run" command. Example
    axlShell("run -b  <your command>")
    where the -b option tells the run command to execute your job and return without waiting for it to finish
    if your command is a bat file you will also need to use the "-s" option
