  3. Changing spacing constraints when opening Allegro
  • Replies 23
  • Subscribers 163
  • Views 29140
Mstrghettorigg
Mstrghettorigg over 14 years ago
Hi All,
 I was wondering if anyone can guide me in the right direction.
I'm trying to make it so I can set the bottom SMD pin to TH distance when allegro starts up.  This will need to be done to all files being opened.
I'm not familiar with writing skills, but I was wondering if anyone has ran into similar Skill file or at least guide me in the right direction.
I looked through some forum and it looks like I can use axlCmdRegister and axlTriggerSet commands to run the skill automatically once I have the skill file create.
I think this command is where I need to get started from, but I don't think it's that simple.
axlCNSSetSpacing("" TOP 'Thru Pin_SMD Pin .050 INCH)
Any help will be appreciated.
Thanks!
  • DE202408202727
    DE202408202727 over 14 years ago
    Remove the space before the (
    ie.  axlTriggerSet('open 'TH_SMT)
    (load "TH_SMT.il") should be in you ilinit file.
  • Mstrghettorigg
    Hi Dave,
    Sorry for not getting back earlier.  I've been little busy with work.
    So I tried it as you have suggested.  (load "TH_SMT.il") in ilinit file
    Tried the axlTriggerSet('open 'TH_SMT) in env, ilinit, skill file one at a time and I still cannot get it to run.
    The TH_SMT.il is loaded since if I type TH_SMT in the command line the skill will run, but it does not automatically run and change the constraints.
    Please advise if you can think of anything else that I may be doing wrong.
  • DE202408202727
     axlTriggerSet should call the Skill function name - not the name of the Skill file (unless they are the same of course)
  • Mstrghettorigg
    Hi Dave,
    I can't seem to figure this out.  I must be missing some steps here.  My skill file name is TH_SMT.il and inside contains
    (defun TH_SMT () axlCNSSetSpacing(nil "ETCH/BOTTOM" 'thrupin_smdpin axlMKSConvert(50 "mils") ))
    This file seems to work just fine if I type in TH_SMT in the command line with allegro.ilinit calling out
    (load "TH_SMT.il")
    I just can't seem to get it to run this automatically when I open the board.
    I entered axlTriggerSet('open 'TH_SMT) in the allegro.ilinit file, but it does not work.
    I also tried in in env file but it did not work either.
    Any help would be appreciated.
     Thank You!
  • DE202408202727
    All that looks good. Are you sure that your allegro.ilinit file is being called? There is a heirarchy for the calls so maybe it's finding another copy? Put some messaging into your TH_SMT function for testing.
