  3. How to Read a text file as Text Type
  • Subscribers 158
  • Views 15678
Geoff
Geoff over 13 years ago
I am having trouble reading a text file and having it stay as text. I guess skill expects every text item to be quoted.
Is there a way I can read it as text?
second choice: can I split each line into an Array?
sample_infile.il
775 640 N74011018 TP30CIR_TOP Top
5045 570 N74011128 TP30CIR_TOP Top
5175 1015 GND TP30CIR_TOP Top
55 1310 GND_EARTH TP30CIR_TOP Top
650 140 VOUT TP30CIR_TOP Top
500 140 MODEM_48VIN- TP30CIR_TOP Top
500 190 MODEM_48VIN+ TP30CIR_TOP Top
75 595 48VIN- TP30CIR_TOP Top
775 1190 48VIN+ TP30CIR_TOP Top
(defun Read_String ()
 FileData=infile("sample_infile.txt")
 LocLine=""
 while( LocLine!=nil
  LocLine=lineread(FileData)
  printf("%n    %n    %L\n" nth( 0 LocLine) nth( 1 LocLine) nth( 2 LocLine))
 );while
);defun
Skill > Read_String
775   640   N74011018
5045   570   N74011128
5175   1015   GND
55   1310   GND_EARTH
650   140   VOUT
500   140   (MODEM_48VIN - TP30CIR_TOP)
500   190   (MODEM_48VIN + TP30CIR_TOP)
E-
E- 75 595 48VIN- TP30CIR_TOP Top
E-             ^
E- SYNTAX ERROR found at line 8 column 13 of file sample_infile.txt
E- *Error* lineread/read: syntax error encountered in input
ERROR
Skill >
Things of note:
1. The minus and plus sign in MODEM_48VIN-  and  MODEM_48VIN+ gets separated in the output, and that makes a list of two items: (MODEM_48VIN - TP30CIR_TOP)
2. Program chokes on 48VIN-  maybe because it starts with a number and ends with a minus sign.
  • eDave
    eDave over 13 years ago
    Use gets instead of lineread:
     FileData = infile("sample_infile.txt")
     while(gets(str, FileData)
      LocLine = parseString(str)
      printf("%s    %s    %s\n" nth( 0 LocLine) nth( 1 LocLine) nth( 2 LocLine))
     );while
    );defun
  • eDave
    Oops. Use this:
      LocLine = parseString(str, " ")
     );while
     close(FileData)
    );defun
  • Geoff
    That worked good except it seems to not exit gracefully from the While loop:
    Skill > Read_String
    775   640   N74011018
    5045   570   N74011128
    5175   1015   GND
    55   1310   GND_EARTH
    650   140   VOUT
    75   595   48VIN-
    775   1190   48VIN+
    E- *Error* fprintf/sprintf: format spec. incompatible with data - "Format is '%s   %s   %s\n', argument #2 is nil"
    ERROR
    Skill >
  • eDave
    You may want to add some checking. ie: when(length(LocLine) >= 3 printf("%s %s %s\n" nth( 0 LocLine) nth( 1 LocLine) nth( 2 LocLine)) )
  • Geoff
    I found the problem. The  text file had some empty lines at the end. Yes, I have to put a check for that.
     Thanks for Your help Dave!
