  3. Assigning Cset to a Region 16.3
  • Subscribers 158
  • Views 13250
Mstrghettorigg
Mstrghettorigg over 13 years ago
Hello All,
I am attempting to assign a Constraints set to a Region that is already on the board on 16.3.  I have obtained the documentation for 16.5 and it looks like command "axlCnsClassTableCreate" would do the trick, but I don't feel that it works for 16.3.
I was wondering if there was an alternative method on 16.3 to accomplish the task of assigning a Cset that already exist on the board to a region with name assigned.
Please let me know if you are able to help!
  • fxffxf
    fxffxf over 13 years ago
    axlCnsClassTableCreate should be available in you have a recent 16.3 ISR installed. It won't be available in the 16.3 base release. You can test for its presence by making sure getd('axlCnsClassTableCreate) doesn't return nil. You will need to use 16.5 documentation to see how it works.
  • Mstrghettorigg
    It looks like we are too out of date.  Hopefully we will be getting renewed soon...
    Thank you for the help though!
