  3. Extract all symbols/nets from a design
  • Replies 16
  • Views 16782
serpens
serpens over 13 years ago
Hi, I'm new with SKILL, I try to do some code and it works, but as I trying to go deeper I found some issues. I start to work with the database and as a exercise I want to extract all reference designators (or net names) from a board.
However, I was looking trough Allegro® User Guide: SKILL Reference but can not find nothing. I don't want from you to give me the code, I just need some advice in some methodology how to extract such things from database.
I found only this axlExtractMap (there is an example how to extract all net names) but if I understand it correctly it use already existing report files and I looking fore something without external files.\
Miro
  • serpens
    Mod can delete...
  • serpens
    Mod can delete...
  • serpens
    Is there some way how to input formated text in this forum or attach some file, or i need to use external space?
    However, I want to thank you both, with your help I was able to create this:
    foreach( moAllNets axlDBGetDesign()->nets
    moTP = 0
    printf( "\n %s - " moAllNets->name)
    foreach( moNetBranch moAllNets->branches
    foreach( moBranchType moNetBranch->children
    if( moBranchType->objType == "pin"
    then
    moIsTP = substring( moBranchType->component->name 1 2)
    if( moIsTP == "TP"
    then
    printf( "%s " moBranchType->component->name)
    moTP = 1
    );end if
    );end if
    );foreach
    );end foreach
    if( moTP == 0
    print("Missing Test Point")
    );end for each
    Now I can continue and finetune it, but this is the core which I need. If you have any ideas how to make it shorter I glad to hear you.
    Miro
  • D912349
    D912349 over 13 years ago
    there is a way to read a text from a file..
    try using gets function. also take a look at infile function to open ports to read a file..
  • eDaNoy
    eDaNoy over 13 years ago
    - list_2 of redfdes of symbols for each net which are connected to this net (strugling)
    you can use axlDBGetConnect to find all the elements you want.. please refer to the Cadence documentation
