  3. Constraint set up for delta and tolerance
  • Replies 9
  • Views 24920
jemarods
jemarods over 13 years ago
Hi all,
 What is the difference of setting up a delta of 0 , tolerance of 50.... (so 0:50)
with
no delta, tolerance of 100...... (so :100)
since in my case, a target appears if a delta is used.
follow up question:, how does constraint manager identifies a target net....?
Thanks in advance!!
  • mcatramb91
    mcatramb91 over 13 years ago
    You are correct.  You would think that the results of using either 0:50 or :100 would be the same but the controlling factor is where the target ends up when using 0:50.  Clicking on the Length column will sort the lengths so you can see which ones are out of range of the match and where the target should be set to. Right Mouse button on the Delta:Tolerance field to set the target to works the best, that is if you don't have a target net for the group to be matched to.
    Good Luck,
    Mike Catrambone
  • jemarods
    Thanks again Mike,
     BR!
  • eDaNoy
    eDaNoy over 13 years ago
    Good day Dennis,
     I cant access your file. I cant manage to login using my cadence account.
    Need help.
    thanks
  • LouShay
    LouShay over 6 years ago in reply to Dennis Nagle
    Hey Dennis, The link no longer takes you to the presentation. Is there anyway to still get it? After all it's only been 7 years :)  Thanks!   -lou
