  3. How to get a proceeding command?
  • Subscribers 159
  • Views 13328
myhan
myhan over 12 years ago
 I am making a skill file to change line width.
But It needs to change according to current command, "Add Connect" or "Add Line".
So I want to know how to get a procedding command.
Please let me know.
Thanks in advance.
  • D912349
    D912349 over 12 years ago
    Hi myhan,
    I am not sure if their is a way to get a preceeding command using skill because most of axl functions work during idle mode (or no command is active).
    but regarding changing line width, you can use axlDBCreateLine.
    try this.
    axlSetFindFilter(?enabled `("ALL" "clines" "lines") ?onButtons `("noALL" "clines" "lines"))
    axlEnterPoint()
    point = axlLastPick(nil)
    axlSingleSelectPoint(point)
     lineDbid = car(axlGetSelSet())
    (foreach item lineDbid->segments
               axlDBCreateLine(item->startEnd, preferedWidth, item->layer)
     axlDeleteObject(lineDbid)
    note: preferedWidth is variable for width you wan to change
    Hope this helps
  • myhan
    Thanks for your prompt response.
    Manyong
