  3. Delete confirmation popup
  • Subscribers 159
  • Views 13922
Yann00
Yann00 over 12 years ago
Hi guys, another topic (:
Have you got a way to delete confirmation popup?
When I do an axlSaveDesign() in my SKILL code I get "This file already exists, overwrite?"
And I have to click Yes, But my SKILL code represents an automatisation of something so,...
Best regards
  • D912349
    D912349 over 12 years ago
    Hi Yann00,
     I am not sure if their is a way to remove the pop up, but what I do is to skip the pop up is to check through skill if the file already exist. you can use isFile function for this. after checking if isFile returns t then delete first the file before saving. in that way you are sure that the filename you are saving do not exist on that directory..
    Hope it helps.
  • fxffxf
    fxffxf over 12 years ago
     add to the axlSaveDesign arguments
         ?noConfirm t
  • Yann00
    Again, Really thanks guys.
