  3. Placing the padstacks as per the pin location entered in...
  • Replies 8
  • Subscribers 160
  • Views 17457
Placing the padstacks as per the pin location entered in Text file
Arun Koyyan
Arun Koyyan over 12 years ago
Hi All,
I have to create a footprint for a part for which the datasheet is given limited details. I have the X and Y co-ordinates for all the pads given in the datasheet. So I do have to place all the pads one by one taking X, Y co-ordinate from the datasheet. It consumes most of my time if the pin count is more than 50.
So, is it possible to import any text file to allegro in which all the pin location is provided to place all the pins in one shot? And how to map the padstack in this case?
Hope someone can help me out.
Thanks & Regards
Arun
  • oldmouldy
    oldmouldy over 12 years ago
    Certainly "A" way to do this is to record a script and then modify it for the actual locations. File>Script, give it a name and Record, use Layout Pins, pick you Padstack, place a couple of pins, right-click>Done, then File Script, Stop. You will have a script named <your script name>.scr in the current PCB Editor directory. Open this with a text editor, you will see the "pick" commands that placed the pins at the X/Y locations, add more "pick commands" for your required pin locations and save the modified script, Start a new Symbol and File>Script, locate the script and Run. You might want to try this with a few added picks before going for hundreds! Also note that the Picks do not reference the grid at all They do use the Units, so best not change them from the units the script was recorded for!
  • Arun Koyyan
    Thanks a lot for your quick reply.
    Unfortunately this step is not working for me. I have some doubts actually:-
    1. Do I need to selct the padstack before running the script?
    2. Do I need to delete the "pick rel grid" command got generated in the Text file?
    Regards
    Arun
  • oldmouldy
    NO, you don't need to pick the padstack. When you recorded the script, you recorded the entire process to place two pins with the required padstack from the Padstack list, in the required location(s). You did do that? Maybe not...
    Of course, the drawing parameters will need to be set to allow the pin parameters you need..
    Maybe placing 500 pins manually would be a better way?
    setwindow pcb
    trapsize 249
    generaledit
    trapsize 314
    add pin
    setwindow form.mini
    FORM mini pad_browse
    fillin "Pad100cir62d"
    setwindow pcb
    pick 0 0
    pick 200 100
    pick 400 200
    prepopup 1126.3 1100.4
    done
  • Arun Koyyan
    Thanks a lot..
    It is working for me now..:)
    great relax... :)
    Regards
    Arun
  • djhutchi
    djhutchi over 12 years ago
    SPB 16.6 has the ability to import & export pin location data to a csv file
