  3. Detect the presence of a form or an active command
  • Subscribers 159
  • Views 14148
SkilSiao
SkilSiao over 12 years ago
Hi all,
is there a function to detect the presence of a form of a command?
I have a recorded script like this
axlShell("pbar create; setwindow form.pbarCreate; ...")
is there any function to check that the form.pbarCreate is present after
the first command of "pbar create"? Or the command of "pbar create" is still active ?
 Thanks in advance.
  • fxffxf
    fxffxf over 12 years ago
     Try axlUIWExposedWindowName("pbarCreate") if it returns t the window is opened.
  • fxffxf
     Oops correct function, try axlUIWExposedWindowByName("pbarCreate") if it returns t the window is opened.
  • SkilSiao
    Hi fxffxf,
    Thanks alot. the function is axlUIWExposeByName(t_windowName).
