  3. axlChangeLayer documentation issue or are lines really ...
  • Views 17337
axlChangeLayer documentation issue or are lines really unsupported
Ejlersen
Ejlersen over 13 years ago
Hi
I'm working on a large number of package symbols where the subclass (not class) needs to be changed for number of lines.
Using the new axlChangeLayer (16.6) command that in the documentation should support both lines, clines, segments, shapes and text I keep getting the following error (nid is the object id)
axlChangeLayer(nid "PACKAGE GEOMETRY/ASSEMBLY_TOP")
E- (SPMHGE-522): Changing line to a different class is not supported.
Anyone that has used this command with succes?
Best regards
Ole
  • aCraig
    aCraig over 13 years ago
    Messing with this a bit more. I can change from Conductor/L1 to Component Geometry/Assembly_Top. But it errors if I try to change it back to L1. I can also change from Conductor/L1 to Conductor/L2 and back.
    Looks like the object has to reside on a Conductor layer to be changed. You should probably ping Cadence.
    Craig
