  3. APD [Allegro Package Designer] Enquiries
  • Subscribers 159
  • Views 13066
Lee Kar Leong
Lee Kar Leong over 12 years ago
  • is that any idea I can view the padstack file (*.pad) in text format w/o lauching any Cadence Tool
  • How to run certain function automatically when tool is startup, i have tried with bad luck. Enclosed is the il file, refer below on my ilinit file
  • I have found an issue, which that when we create a Xsection, if the Subclass name is different from the layer name in padstack. the particular padstack wouldn't be imported. Any idea how to solve this issues.
  • what is the different when I set "0" and "leave blank " in constraint manage
allegro.ilinit
setSkillPath(buildString(append1(getSkillPath()  "D:/dump_files/041613")))
;    Lines preceded by ";" are comment lines
; replace D:/skill..... above with your path to the skill files. Remember the
; quotes. This MUST have a forward slash.
; The next line will print on the Command line in Allegro "allegro.ilinit file loaded".
; This is a good way to confirm the allegro.ilinit file actually is loaded.
load("tcf_in.il")
TS_tcfIn.autoload = "tcf_in.il"
axlTriggerSet('open 'TS_tcfIn)
;axlCmdRegister("TS_tcf_in" 'TS_tcfIn)
please help if any one know how to solve
tcf_in.il
  • aCraig
    aCraig over 12 years ago
    • Only way I can think of to view a padstack in text format w/o lauching a Cadence tool is to use "extracta"
    • Place the command at the end of your SKILL file or in your allegro.ilinit. See below
    • When building a padstack only define TOP, BOTTOM and INTERNAL layers, then when added to the database each layer will be updated
    • Not sure
    This is a file called myLoad.il
    (defun myLoad ()
      do stuff...
    ); myLoad
    myLoad()
     or you can place myLoad() in your allegro.ilint and not at the bottom of the SKILL file.
    Craig
