  3. s_backColor with grid cells
  • Subscribers 159
  • Views 13687
Ejlersen
Ejlersen over 12 years ago
Hi
How can a background color for grid cells be set to anything apart from the standard colors shown in the documentation.
I've seen this done in grid cell based forms and have so far not been able to figure this out.
It works for setting cell->backColor to 'green, 'black, 'white etc. but I would like to use rgb or color palette numbers
Anyone know the secret to this?
Best regards
Ole
  • fxffxf
    fxffxf over 12 years ago
     see the example code in <cdsroot>/share/pcb/examples/skill/form
     the files are fgrid.il/fgrid.form
    load fgrid,il and then type gridtest
  • Ejlersen
    Hi
    Thats the example I've been looking at,but it does not show using rgb color codes for setting the background color of a cell.
    I've tried cell->backColor = '(100 100 100) without any luck, I've also tried passing color palette results with no luck
    I've tried on 16.6s006 and 16.6s008
    Best regards
    Ole
  • fxffxf
    Grid color supports a set of predefined colors (e.g. 'yellow 'red 'green etc) or Allegro design colors. Allegro design colors require the allegro color number which corrosponds to a rgb value stored in the Allegro database (see axlFormColorize  and axlColorDoc for more info). It doesn't support the ability to assign abitrary rgb values to a cell.
  • Ejlersen
    Hi
    Yes, you're correct - it works with the 'background option on colorize - thanks for pointing me in the correct direction for doing this when initializing the form instead of when I created the cells.
    Best regards
    Ole
