  3. Fillet shape ?
  • Replies 8
  • Subscribers 159
  • Views 17122
Fillet shape ?
luanvn81
luanvn81 over 12 years ago
 Hi all!
 I'm trying to write a code to check fillet , but I don't know how to know  if a shape is "fillet shape". My version is 16.3( in this, when i show element fillet shape => "Shape is fillet"). Pls help me ?
thanks
Luan.
  • fxffxf
    fxffxf over 12 years ago
     If you have the dbid of a shape then
       shape->fillet == t
    if the shape is a fillet shape
  • luanvn81
     Hi fxffxf!
    Thank for your advice ! That is what I need.
    Luan.
  • luanvn81
     Hi!
     One more question that is How to know a fillet shape is belong to which cline? When I show element a fillet shape, i found that It's only connect to a via or a pin. Can you help me do that.
    Tks
    Luan.
  • Pawandeep
    Pawandeep over 12 years ago
    You can explore the axlDBGetConnect function by passing the dbid for shape as input and getting the parent Net or Cline etc
    -Pawan
  • luanvn81
     Hi Pawandeep !
        I have tested follow your advice, by passing the shape's dbid to get parent of Cline,  It got all clines of the shape's net . So I don't know which cline belongs to processing shape. Another suggestion ?
    Tks
    Luan.
