  3. Skill command not working at command line
  • Subscribers 158
  • Views 15468
budnoel
budnoel over 12 years ago
Hello - When I type in SKILL at my command line I expected to get Skill>  This does not work for some reason.  Here's what I get:
Command > SKILL
E- Command not found: SKILL
Command >
Anyone?
  • Pawandeep
    Pawandeep over 12 years ago
    refer below
  • oldmouldy
    oldmouldy over 12 years ago
    You need to start PCB Editor with "at least" an Allegro PCB Design L (legacy) license to get the Skill Command Prompt, this is not available with any of the OrCAD PCB Editor licenses - you can run Skill routines with any PCB Editor product license when the routines, and contexts are pre-loaded at start up.
  • budnoel
    That appears to be the issue.  I'm using OrCAD PCB Editor (OrCAD PCB Designer Professional) v 16.6  Thanks.
