  3. dbid removed
  • Subscribers 160
  • Views 13118
dbid removed
Season
Season over 12 years ago
My skill runs well in allegro 16.3.
In 16.5 and 16.6, it can run in some boards, but fails in other boards.
The error, "dbid: removed" oftern occurs in failing boards
Did anyone encounter this problem? thanks.
  • edaMac
    edaMac over 12 years ago
    Hi Season,
    Can you be more specific on how your skill works(RUN). Based on my experience, I only encounter the  "dbid:removed" problem is when I stored any dbids to a variable(ex. list), then do other commands. Then the time I want to retreive the dbids, it's already removed. So I think the best solution here is don't store any dbids unless you will use it directly. Maybe you can store NAMES (ex. Net names) for later use.
    I Hope this helps. Thanks
