  3. String size for grid
  • Subscribers 158
  • Views 14122
D912349
D912349 over 12 years ago
Anyone knows how to extend size/number characters for fieldtype STRING at grids?. default size is limited to 16 characters.
Thanks!
  • eDave
    eDave over 12 years ago
    I Don't see this restriction. I tired with "->colWidth = 25" and it worked fine (in 16.6).
  • D912349
     If I set colWidth to 25, the field only widens but number of characters is still restricted to 16. I am not sure, but is thier something to do with the fieldType? the fieldType that I use is "STRING.
  • fxffxf
    fxffxf over 12 years ago
    You want the fieldLength parameter of the formGridCol defstruct used with axlFormGridInsertCol.
    Example (for more complete example see <cdsroot>/share/pcb/examples/skill/form/grid) :
    p = make_formGridCol()
    p->fieldType = 'STRING
    p->colWidth = 0    ; autosize visible column width
    p->fieldLength  = 32  ; maximum length of string permitted
    axlFormGridInsertCol(fw "grid" p)
  • D912349
    Code works!
    Thanks.
