  3. axlGeoPointShapeInfo and axlGeoPointInShape issue
  • Subscribers 159
  • Views 13425
Ejlersen
Ejlersen over 12 years ago
Hi
I've tried using the above 2 functions with the pin dbid->xy and constraint region dbid
The function always return nil -  can it not be used with constraint regions?
Best regards
Ole
  • djhutchi
    djhutchi over 12 years ago
    They appear to work correctly in 16.6 S016:
    Skill > s3=car(reverse(axlGetSelSet()))
    dbid:236524648
    Skill > s3->??
    (prop nil bBox
        ((10200.0 16025.0)
     (10500.0 16275.0)
        ) readOnly
        t net nil objType "polygon"
        segments
        (dbid:236353288 dbid:236353328 dbid:236353368 dbid:236353408) nSegs 4 isRect
        nil layer "CONSTRAINT REGION/ALL" parent nil
        parentGroups
        (dbid:236524488)
    last pick:  10350.00  16200.00
    Skill > v1=car(axlGetSelSet())
    dbid:236525128
    Skill > v1->??
    (prop nil bBox
        ((10340.0 16168.0)
     (10384.0 16212.0)
        ) readOnly
        t net dbid:236324752 objType "via"
        pads
        (pad:271819184 pad:271819160 pad:271819136 pad:271819112 pad:271819088
     pad:271819064 pad:271819040 pad:271819016 pad:271818992 pad:271818968
     pad:271818944 pad:271818920 pad:271818896 pad:271818872 pad:271818848
     pad:271818824 pad:271818800 pad:271818776
        ) branch dbid:236392280 fixedByTestPoint
        nil isThrough t xy
        (10362.0 16190.0)
        testPoint nil name "VIA" startEnd
        ("ETCH/TOP" "ETCH/BOTTOM") rotation 0.0 symbolEtch nil
        parent dbid:236392280 mirrorType "NO" isMirrored
        nil definition dbid:236327552 parentGroups nil
    Skill > axlGeoPointInShape(v1->xy s3)
    t
    Skill > axlGeoPointShapeInfo(v1->xy s3)
    (inside nil)
    Skill >
  • Ejlersen
    Hi
    That's really weird, I'm using 16.6s016 as well
    I'll have a go at it again and see if I can get it working, otherwise I'll post my sample.
    best regards
    Ole
