  3. removing underscore on refdes
  • Subscribers 160
  • Views 16326
seyerfred
seyerfred over 12 years ago
Hi all,
is there possible skill code that can rename refdes by batch or just removing _1 ~ _x cause by using moduling groups?
and it will change refdes as report from symbol..
Thank you
  • Ejlersen
    Ejlersen over 12 years ago
    Hi
    I would think that you could just use Logic->Rename refdes to just do an ordinary reference renaming and then backannotate it to schematic.
    That should strip everything except the letter part of your reference designators.
    Best regards
    Ole
  • seyerfred
    Hi Ole
    Logic>autorename refdes will create a unique refdes intire design, all i want is to retain refdes and delete only underscore extension(with repeated refdes on design).
    by the way is there other way axlSelectByName("REFDES" sym)? i want to modify procedure of set_refdes.il to merge autosilk refdes but the the axl depend on ticked refdes on symbol..
    procedure( _find_refdes(sym tlayer)
    prog( list(child l_children o_type o_layer match_loc)
    l_children = car(axlSelectByName("REFDES" sym))->children
    foreach(child l_children
    o_type = child->objType
    o_layer = child->layer
    if(o_type=="text" && o_layer==tlayer then
    match_loc=child->xy
    axlClearSelSet()
    return(list(child match_loc))
    Thank you
  • eDave
    eDave over 12 years ago
    You can use axlRenameRefdes. You will have to go through each symbol.
    eg  axlRenameRefdes("U1_1" "U1")
    Take care that the new refdes doesn't already exist because  axlRenameRefdes will just swap them.
  • seyerfred
    Thanks Dave,
     could it be possible to create backup of all refdes then axlRenameRefdes get the backup as reference to rename all at one time?
    Thank you
  • eDave
    If you can understand the following code it might help:
    refdesList = setof(refdes, axlDBGetDesign() ->symbols ~>refdes, refdes)
    tempRefdesList = mapcar(lambda((refdes), and(tempRefdes = strcat(refdes, "_TEMP"), axlRenameRefdes(refdes, strcat(refdes, "_TEMP")), tempRefdes)), refdesList)
    forall(result, mapcar(lambda((refdes), axlRenameRefdes(refdes, car(parseString(refdes, "_")))), tempRefdesList), result)
