  3. Copy, edit, then save padstack
  • Replies 8
  • Subscribers 159
  • Views 17614
mikebystedt
mikebystedt over 12 years ago
Newbie question,
Old timer in SKILL (IC), new to Allegro axl functionality.
 I simply want to grab an existing padStack and copy it.  Change the flash name for a specific pad on a specific layer (thermal), and save it to the new padId.  Then save it to the design.It seems to be readOnly, so I'm not able to modify any of the properties.  Any suggestions?
* I used axlCopyPadStack(), and grabbed the dbId for it, then tried to modify it to no avail.
padId = axlDBGetPad(padStack pad->layer "THERMAL")
padId->flash = flashName
Can't seem to modify it.  Also wish to pick a pin and change/swap the padstack for it.  Not sure if I will run into similar issues.  Any help here would be greatly appreciated.
Regards, Mike.
  • eDave
    eDave over 12 years ago
    Welcome to the axl world!
    Try using axlPadstackEdit.
  • mikebystedt
    "Currently only global padstack settings are supported. Editing pad layer characteristics in not
    allowed."  (Not my typo).
    Looks like axlPadstackEdit only allows me to modify properties for the padstack.  I actually need to change the "flash" name of a specific thermal pad.  I have the id for the pad, but I can't modify the readOnly status to change it.
     Thanks eDave,  One of my new co-workers said you were the man to talk to if possible.  I guess you are slightly famous.
     Any other ideas?  Maybe I'm just too new and missing something here.
     Thanks, -Mike
  • mikebystedt
    This isn't looking very promising.  Do I have to write a procedure to read out all of the details of an existing padStack and modify the flash names for the pad/layer before adding it using axlDBCreatePadStack()?  I was really hoping for a quick copy, then a simple change to the flash name for the new padStack.
    Is this possible?  Or do I have to do it the hard way?
     -Mike
  • mikebystedt
     Dave, I found this suggestion from you in another post.  Is this the only way to get the job done?  What use is axlDBCopyPadstack() if we can't modify it at all???  Very curious.  Thanks.  -Mike
    I believe that method 1 is the only one that will work well - and it does work.
    You need to define the pads for every layer using make_axlPadStackPad and then create the padStack using axlDBCreatePadStack before using axlPadstackToDisk.
    Works for me.
    Dave
  • eDave
    Don't worry. You can do it:
    See the below code. It does something else and contains calls to some of my private functions but it should give you a clue.
    Especially look at the  make_axlPadStackPad command.
    Cheers,
    Dave
    defun( ReplaceNarrowSMDPads ()
     let((minPadWidth, minPadDia, dx, widthStr, diaStr, pins, psid, cuPad, suffix, newName, pads, padStruct, exts, xLen, yLen, newWidth
    layer, flash, figureSize, newPad, pinsToReplace, replaceList, p, fileName)
    minPadWidth = MM2Units(0.27)
    minPadDia = MM2Units(0.37)
    dx = MM2Units(0.025)
    pins = setof(pin, AFn_findTypeObjects("pins"), FindNarrowSMDPadsOnPin(pin, minPadWidth, minPadDia))
    foreach(pinName, unique(pins ~>name)
    psid = axlLoadPadstack(pinName)
    cuPad = axlDBGetPad(psid, "ETCH/TOP", "REGULAR")
    exts = cuPad ->bBox, xLen = BboxX2(exts) - BboxX1(exts), yLen = BboxY2(exts) - BboxY1(exts)
    newWidth = min(xLen, yLen) + dx
    sprintf(widthStr, "%d", round(ToMM(newWidth) * 101))
    diaStr = widthStr
    cond(
    (rexMatchp("^[0-9]+X[0-9]+[_]*.*$", pinName); Rect pad
    sprintf(newName, "%sX%s", car(parseString(pinName, "X")), widthStr)
    (rexMatchp("^[0-9]+O[0-9]+[_]*.*$", pinName); Oval pad
    sprintf(newName, "%sO%s", car(parseString(pinName, "O")), widthStr)
    (rexMatchp("^[0-9]+C[_]*.*$", pinName); BGA ball
    sprintf(newName, "%sC", diaStr)
    suffix = when(index(pinName, "_"), strcat("_", cadr(parseString(pinName, "_"))))
    when(suffix, newName = strcat(newName, suffix))
    unless(axlLoadPadstack(newName)
    printf("Creating new padstack: %s\n", newName)
    pads = psid ->pads
    padStruct = nil
    foreach(pad, pads
    exts = pad ->bBox
    unless(zerop(xLen) || zerop(yLen)
    layer = cadr(parseString(pad ->layer, "/"))
    flash = unless(pad ->flash == "", pad ->flash)
    figureSize = if(rexMatchp("^[0-9]+C[_]*.*$", pinName); BGA circle
    then list(xLen + dx, yLen + dx)
    else list(if(xLen <= yLen, xLen + dx, xLen), if(xLen <= yLen, yLen, yLen + dx))
    newPad = make_axlPadStackPad(?layer layer, ?type pad ->type, ?figure pad ->figureName, ?flash flash, ?figureSize figureSize, ?offset pad ->offset)
    padStruct = cons(newPad, padStruct)
    axlDBCreatePadStack(newName, nil, padStruct)
    pinsToReplace = setof(pin, pins, pin ->name == pinName)
    printf("Replacing %s with %s on %d pins...\n", pinName, newName, length(pinsToReplace))
    ;axlReplacePadstack(pinsToReplace, newName); This causes exploded pads and connectivity problems
    replaceList = cons(list(pinName, newName), replaceList)
    ); foreach pinName
    when(replaceList
    p = axlDMOpenFile("ALLEGRO_SCRIPT", "ReplacePadstack", "w")
    if(p then
    fileName = get_filename(p)
    fprintf(p, "setwindow pcb\n")
    fprintf(p, "generaledit\n")
    fprintf(p, "replace padstack\n")
    fprintf(p, "setwindow form.mini\n")
    foreach(pinPair, replaceList
    fprintf(p, "FORM mini oldname %s\n", car(pinPair))
    fprintf(p, "FORM mini newname %s\n", cadr(pinPair))
    fprintf(p, "FORM mini replace\n")
    fprintf(p, "fillin yes\n")
    fprintf(p, "done\n")
    drain(p)
    axlDMClose(p)
    axlShell("replay ./ReplacePadstack.scr")
    deleteFile(fileName)
      else
    axlUIConfirm("Error: Could not create Replace Padstack script file", 'error)
