  3. Simple Skill script made Allegro frozen
  • Subscribers 159
  • Views 14353
JGONG
JGONG over 12 years ago
Hi, I got a very strange issue: my skill script made the Allegro "busy" and frozen. Please refer to the attached picture:
 When I typed in the function name "sp",  the script seems not even started, because it didn't print the "start:" at line 5.  If I click on "X" on up-right corner of Allegro editor windows to close it, Win7 would pop "Application is not responding..." message.
Any help or clue would be appreciated.   Thanks in advance.
Jun Gong
BTW:
 I am thinking whether SKILL has certain limitations that not publish and easy trap a new skill programmer. ex, a string length may have maxim limit, maximum total script length, function length? etc.  Does any one know which document has this information?
  • oldmouldy
    oldmouldy over 12 years ago
    SKILL is interpreted and, as such, it's quite easy to upset the interpreter and not get an answer. Outputs from "printf"s are buffered so you may not see the output until the script completes, if the script never completes... As a preference, use the axlMsgPut to output messages. Start off with something simple, like output a message and then go from there so that you can identify the "break" easily. Refer to the algroskill.pdf, in the doc\algroskill directory of the installation, for PCB Editor specific SKILL functions and the sklangref.pdf, in the doc\sklangref directory for "generic" SKILL functions. Refer to other working examples that have been contributed, like the PCB SKILL forum and the Allegro SKILL Code Library from the Cadence Online Support site, there are also examples in the product installation at share\pcb\examples\skill to illustrate specific SKILL principles.
  • JGONG
     Thank you for your suggestion. I finally found the issue was caused by a infinite loop.axlMSGPut() is great.
