  3. Copying symbols for creating padstacks.
  • Replies 7
  • Subscribers 159
  • Views 15618
mikebystedt
mikebystedt over 11 years ago
I'm trying to copy padstack information so that I can create a slightly modified version.
As an example:
When I grab the data structure for the original pad type, it's a string ("ANTIPAD", "THERMAL", etc...) instead of a symbol.
So I can't easily pass it along.
I had to put it into a case statement to assign the type that I want.
Then I tried to use stringToSymbol and use that so I didn't need a case statement at all.
Any suggestions on why this doesn't seem to work?
ps = axlLoadPadstack(padStackName)
padId = car(ps->pads)
padId->type returns "THERMAL" (a string and not a symbol).
newPad->type = stringToSymbol(padId->type)
*This is no good.*
 /***  This seems to work though.  **/
case(padId->type
("ANTIPAD" type = 'ANTIPAD)
("THERMAL" type = 'THERMAL)
("REGULAR" type = 'REGULAR)
(t type = nil)
);End type case.
newPad->type = type
I'm obviously doing something incorrectly here.  Any help is greatly appreciated!
-Mike
  • eDave
    eDave over 11 years ago
    Neither should work. I'm reasonably sure that you can't edit pads that way. I think you need to create a new padstack using axlDBCreatePadstack and the make_axlPadStackPad defstruct method.
    axlPadstackEdit(nil nil) will tell you which attributes are editable.
  • mikebystedt
    Hi Dave, that was just a snippet leading up to using the above functions.
    Regards, -Mike
    procedure( copyPadStack()
      let((form padStackName newPadStackName ps drill_data newPad padList figureSize   )
    form = ConnectivityForm
    padStackName = axlFormGetField(form "padstack")
    newPadStackName = "Mike"
    /*** Get Drill Data for padStack ***/
    drill_data = make_axlPadStackDrill(
    ?fixed ps->fixed
    ?uvia   ps->uvia
    ?keepout   ps->keepout
    ?drillDiameter ps->drillDiamter
    ?figure ps->figure ;;symbol
    ?figureSize ps->figureSize
    ?offset ps->offset
    ?plating ps->plating ;;symbol
    ?drillChar ps->drillChar
    ?multiDrillData ps->multiDrillData
    ?holeType ps->holeType ;;symbol
    ?slotSize ps->slotSize
    ?holeTolerance ps->holeTolerance
    ?drillNonStandard ps->drillNonStandard ;;symbol
    ;count = 1
    padList = nil
    mikePad = nth(0 ps->pads)
    foreach( pad ps->pads
    ;printf("Mike %d: pad->layer = %L\n" count pad->layer)
    ;printf("    Mike: figureSize = %L\n" pad->figureSize)
    ;printf("    Mike: padType = %L\n" pad->type)
    ;count++
    figureSize = pad->figureSize
    unless(figureSize figureSize = list(1,1)) ;;Don't send in nil values.
    case(pad->type
    (t type = nil)
    );End type case.
    case(pad->figureName
    ("CIRCLE" figure = 'CIRCLE)
    (t figure = 'NULL)
    ;type = stringToSymbol(pad->type)  ;;Doesn't work. Don't know why. Using above case statement.
    newPad = make_axlPadStackPad(
    ?layer cadr(parseString(pad->layer "/"))
    ?type type  ;;Symbol
    ;?figure pad->figureName  ;;Symbol
    ?figure figure
    ?flash nil ;;String
    ?figureSize figureSize ;;Must adjust size to so that it matches the type.
    ?offset pad->offset
    padList = cons(newPad, padList)
    mikeDB = axlDBCreatePadStack(newPadStackName, drill_data, padList)
      );End let.
    );End copyPadStack().
  • eDave
    Hi Mike,
    This one has got me stumped. I can't see why  the stringToSymbol method doesn't work.
    Hopefully Frank can throw some light on this one.
  • mikebystedt
    Thanks Dave, I appreciate you taking a peek at it.
    -Mike
  • fxffxf
    fxffxf over 11 years ago
    makeSymbol converts a string to a symbol
    But I believe all of the axlDBCreatePadstack options that specify a symbol will also take a string, so I would try removing that code and see if passing a string for pad layer type and figureName will work. The only restriction with a string is that it must be upper case.
